Re: Anybody adapt a Cub fast hitch to a Super A?
Posted by mkirsch on January 02, 2009 at 12:13:53 from (64.80.108.55):
In Reply to: Anybody adapt a Cub fast hitch to a Super A? posted by katahdinguy2 on December 27, 2008 at 08:19:01:
UPDATE: Well, my original idea of making adapter plates to allow the use of the Cub brackets and hitch bail isn't going to work. There just isn't enough room down there.
I had hoped the Super A's spacing between the final drives was about an inch wider than the Cub's. That would've been perfect. However, the Super A's spacing appears to be about 1/2" NARROWER than the Cub. Go figure.
I'm on to Hugh's idea of swinging the drawbar under and using that for the bail. It's a downright elegant solution. Wish I'd thought of it last spring before I went to all the trouble of turning the drawbar around for the plow.
[With the 1000 loader on it, you can't put the drawbar up front for the plow, but the previous owner told me that it worked just fine from the rear position, and even had a custom built extension for the depth control. It worked quite well to plow a friend's garden.]
If this works, does anybody have a Super Chief frog in decent shape that they want to get rid of reasonable? I'll have to upgrade my FH Cub plow beam to a 16" bottom to make the old A work a little.
