Re: Super M pistons and sleeve in a regular M?
Posted by the tractor vet on January 02, 2009 at 14:28:17 from (75.19.124.16):
In Reply to: Super M pistons and sleeve in a regular M? posted by littlefarmer on January 02, 2009 at 09:40:40:
Here is my take on this subject and take it for what it is worth. You have a stright old M , ya want to get as much out of it as ya can go with the S/M kit with either fire crater pistons or a dome piston then if ya want more then put a 400 head on it and put in a new cam and lifter , rebuild the governor have the dist. rebuilt and the new update kit if ya can still find one installed rebuild the carb and when done it should get ya around 55-60 hp. and if that ain't enough then get a bigger tractor.
