Posted by TractormanNC on January 02, 2009 at 15:53:12 from (209.42.180.181):
In Reply to: IH 504 hydraulics posted by Mike (WA) on January 02, 2009 at 14:37:42:
Does the tractor have power steering? If so, the valve you mentioned is a flow divider valve to divert 3.5 GPM to the P/S. There should be a 3/4 in. steel tube leading from the flow divider to the right side if the lift cover where the remote valves are. Cut into this steel line and run to the IN port of your loader valve (open center power beyond). Connect a line from the power beyond port of your loader valve to the steel tube that runs to the remote valves on the lift cover. Excess flow from loader valve must be dumped back to sump either at the fill plug or the PTO adjustment plug on the PTO assembly. There were some posts about this awhile back, search the archives for more info. HTH
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
