people confuse automotive and small engine repair sleeves with tractor sleeves all the time. repair sleeves are definitely not designed for high output with their thin walls and mere glue holding them in place. tractor sleeves are, they have pretty thick walls and a hefty collar to hold them in place along with a block machined to keep the sleeve in place should the collar separate.
personally, IH dry sleeves make sense to me. you can have new combustion chambers many times before needing to discard the block, without a sleeve you might have a broken ring at 10, and have to go to 30 to clean up a score, then your block is too big for the next time. wet sleeves seemed scary at first due to coolant in oil potential, but the reliability is still high when you look at the high number of hours before a failure does occur.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
