Re: Farmall M Fan belt removal
Posted by Andy in Beloit on January 02, 2009 at 20:58:51 from (68.114.219.44):
In Reply to: Farmall M Fan belt removal posted by tcanthonyii on January 02, 2009 at 20:42:19:
I'm assumeing that you're talking about the set screw on the pully boss. Since you have it soaked, try tapping it , as if to drive it down into its hole with a chisle or old screwdriver. This can usually break free the last resistance on stuck fasteners. Once the set screw is loose you may need to use a large punch or chisel on the pully boss to break it free on the theaded shaft. Good luck.
