Re: Farmall M Fan belt removal
Posted by Brownie 450 on January 03, 2009 at 04:19:20 from (216.51.158.151):
In Reply to: Farmall M Fan belt removal posted by tcanthonyii on January 02, 2009 at 20:42:19:
Try using the long punch to drive the movable hub section so that the setscrew is in the middle of the "lug" that it is in. Many times the screw is jammed hard against the edge of the slot [lug] & you have to back the movable hub section away from the edge of the slot.
