IHC 350 Utility Live PTO Clutch lever assy.
Posted by John K. from WI on January 03, 2009 at 13:17:39 from (64.201.77.212):
We need the Live PTO Clutch lever assembly for an IHC 350 Utility. This has the planetary type control with the two bands. The lever is alongside the seat for the operator"s right hand, pivots on the top of the axle and connects to the PTO Clutch with linkage. (Different from a Farmall) Need complete assembly not worn or could possibly use good individual parts (lever and pivot shaft). Problem is where the hand lever slips onto the pivot shaft, the holes where the roll pin goes through are worn out and the pivot shaft has been broken and welded. Not a restoration, tractor in use. Email or Phone (262) 492-5819.
