Re: 460 problems
Posted by rvirgil_KS on January 03, 2009 at 15:01:20 from (65.171.114.162):
In Reply to: Re: 460 problems posted by CNKS on January 03, 2009 at 13:42:15:
True, the original coil and resistor combination can be replaced with a true 12 volt coil. Many 6 volt to 12 volt conversions are done that way. If I were doing a conversion I would do it that way and eliminate potential resistor problems.
I was just pointing out the purpose for the ballast resistor in an original 12 volt system and the possibility that the tractor can start and then die when starter is released.
