Posted by Janicholson on January 03, 2009 at 17:23:34 from (68.112.156.69):
In Reply to: Re: the h is jumping posted by tn terry t on January 03, 2009 at 13:34:43:
The tip of the shifter, if worn, can limit the travel of the shift rail, but the issue is probably rear in the shift fork, detent ball/spring, and teeth on the splines of both the gear and the input spline. The forward edge of the shifter slot in the 4th-5th rail can also be built up to increase the travel forward of the rail. There is a detent ball in the rail mount held into the rail notch with a spring. THe spring can become very weak. The total shift engagement on a New H is about 1/2" of shifter movement at the knob. I'll bet yours moves less than 1/8" from the tips of the splines touching to the point the lever stops moving. Good luck, and happy new year. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
