Farmall Super AV clutch release bearing
Posted by APAV on January 03, 2009 at 21:43:35 from (98.232.241.253):
Ok so I have a Super AV tractor split open and I was going to change the cluch release bearing and bushing while I was in there....I had the parts for a farmall A that I never got around to fixing and I have realized that the they are not going to work. The bearing that is in there looks like its graphite and has some chunks out of the edges of in going in about .125 from the edge. I would assume that it should be replaced. Do you know where you can get new graphite? Is there a bearing you can place inside of the housing?
Thanks
