Posted by J.J. from Afton on January 04, 2009 at 07:00:20 from (12.208.127.84):
In Reply to: Re: 460 Oil Cooler? posted by John Athey on January 04, 2009 at 06:45:50:
That is my 560 Standard or Wheatland as I like to call it. The framerail had been removed, cause I had to replace the oil cooler. Over time the plates inside the cooler seperating the coolant and oil had rusted through. So all the antifreeze was being sucked into the freshly rebuilt engine. And in order to put a different cooler in I had to remove the frame rail and put in a good oil cooler after I tested it to be certain. I also ended up replacing the two metal coolant lines in the picture with hose all the way as the lines were full of rust holes.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
