Re: 47 M TRANS
Posted by Rollie NE PA on January 04, 2009 at 11:34:28 from (64.136.26.228):
In Reply to: 47 M TRANS posted by pgo12 on January 03, 2009 at 19:00:55:
Just a thought! If you take off the belt pulley and slide the imput shaft assembly forward would you have enough room to get the bolt and the bearing off the shaft without completely removing the imput shaft? If it could be done this way you would have to use RTV on the gasket/bearing cage when reassembling.
Rollie,
