Re: M timing gears
Posted by Chris NW Ind on January 04, 2009 at 14:11:09 from (64.136.27.229):
In Reply to: Re: M timing gears posted by D Slater on January 04, 2009 at 13:09:14:
I agree. Have a 450 Gas that used to shear the hydraulic pump gear key. You could catch it with the distributor by rotating wires around the cap and retiming. Ultimately, I pulled off regulator valve and found a shimmed up spring and a little piece of metal inside. No more sheared keys.
Chris B.
