Posted by Chris NW Ind on January 04, 2009 at 14:24:49 from (64.136.27.229):
In Reply to: Re: 47 M TRANS posted by Jw-Tc on January 04, 2009 at 07:58:28:
You're trying to get the input shaft out? To get the clutch shaft out without splitting, you have to collapse the pressure plate with 3 5/16" NF x 1.25" bolts, and unbolt the PP from the flywheel. This will give you the wiggle room to pull the clutch shaft clear and drop the clutch and PP. Then pull the input shaft assembly out. You'll have to change the pilot bearing through the belt pulley opening.
That's about all you can do without pulling the trans cover. You should also change the front countershaft seal while you're in there.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
