Re: 1086 broken dowel
Posted by Bemhoff on January 04, 2009 at 14:26:48 from (98.21.28.110):
In Reply to: 1086 broken dowel posted by Andy Motteberg on January 04, 2009 at 08:24:12:
the tractor vet said: (quoted from post at 10:34:07 01/04/09) Just how good of a welder are ya ????? Now if i was to do this i would Pug weld a nut onto the stud and get a good weld to it then i would weld a bolt and then with a piece of 1 inch pipe and a heavy washer and a nut i would PULL the dowel pin out . Now unless ya plan to dril it on a milling machine or a radial drill press there ain't now way you will hit dead center then you will have a mess .
Thanks for the info Tractor Vet and sorry for the delayed response ( had to take a quick trip to my daughters ) I agree with ya that I may end up with a mess if I ended up drilling it. Right now I feel I have a 5/8 nut plug welded on pretty good, next I am going to drop a large flat washer over the nut. Then I am going to do something like you mentioned,l weld a 3/4 nut on top of the 5/8 nut. I should be able to use 2 pry bars with the flat washer tight aginst the larger top nut and pull it up out. If needed I can kinda twist the larger nut a little to help break the dowel free. Was just asking incase some one else had ran into this before, the real difficult part is the dowel is broke off about a 1/16" below the surface at a 30 degree angle or so. And of coarse that surface is part of the rear housing, not the lift arm housing. :( :( :( Thanks again, Bemhoff
