Re: 806 Diesel Starting Problem
Posted by caterpillar guy on January 04, 2009 at 15:44:46 from (205.188.116.73):
In Reply to: 806 Diesel Starting Problem posted by Aaron Roebkes on January 04, 2009 at 14:07:14:
Which pump does it have the RD or the Bosch The reason for asking is the top lid on the RD will leak then lose prime. I think it sounds like the return line is plugged or there is an issue with the governor in the pump. Are you sure it is timed right that will give both problems. If it has the RD pump you have to get #1 up on compression, then take the little cover off the side of the pump the govenor shaft will be there with a mark on it. The cover has just 2 screws in it. Then with the lid off the flywheel housing line the mark up with the 50degree mark BTDC if that is right you should be set.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
