Re: 1086 broken dowel
Posted by 450d on January 04, 2009 at 16:28:55 from (74.85.197.86):
In Reply to: 1086 broken dowel posted by bemhoff on January 04, 2009 at 08:24:12:
As a machinist I have delt with this problem many
times. On a dowel that large if it is in a blind
hole I would drill it with 1/4" hi-roc carbide drill. Just eyeball it close to center drill through the dowel, fill the cavity under the dowel and about half way up the drilled hole with
grease or heavy gear lube. Stick a piece of 1/4" rod in the hole and hit it with a heavy hammer hydraulic displacement will do the rest.
Good Luck
Dave
