Posted by Bemhoff on January 04, 2009 at 17:03:11 from (98.21.28.110):
In Reply to: 1086 broken dowel posted by old on January 04, 2009 at 08:24:12:
450d said: (quoted from post at 17:28:55 01/04/09) As a machinist I have delt with this problem many
times. On a dowel that large if it is in a blind
hole I would drill it with 1/4" hi-roc carbide drill. Just eyeball it close to center drill through the dowel, fill the cavity under the dowel and about half way up the drilled hole with
grease or heavy gear lube. Stick a piece of 1/4" rod in the hole and hit it with a heavy hammer hydraulic displacement will do the rest.
Good Luck
Dave
Thanks for the reply Dave, I think I am going to try pulling it out first. I already have a nut welded on to it so I might as well give it a shot. I will probably try your method after that. I will probably be best to use a mag drill so things aren't as hard to hold in place. I'll let you know how it goes. Again thanks for the info. :wink:
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
