You really need to get a voltage reading both before you start it and after it is running.
A fully charged battery, with surface charge removed, should be 12.6 volts, 2.1 volts per cell.
If the battery is boiling at 14.5 volts or less, replace the battery.
If the voltage is above 14.5 volts check the wiring and connections. Make sure that the voltage sensing lead has battery voltage on it at all times. If the wiring is OK replace the alternator.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
