Re: 47 M TRANS
Posted by Owen Aaland on January 04, 2009 at 18:29:58 from (65.161.86.88):
In Reply to: 47 M TRANS posted by Jw-Tc on January 03, 2009 at 19:00:55:
Once you get the belly pump out, remove the drive coupler. Take out the cap screw retaining the yoke on the rear shaft and remove the yoke. (It should come out by sliding between the ears of the clutch shaft yoke with the clutch shaft still in place.) With the yoke removed you should be able to remove the input shaft assembly and have access to replace the pilot bearing.
