Re: spring startup
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Try this... on April 02, 2000 at 14:26:34 from (167.142.20.220):
In Reply to: spring startup posted by Doug S. on April 02, 2000 at 13:06:08:
Doug- You're probably being overly cautious, but... Try this procedure, it's always worked for me. Drain the fuel tank and flush it with some fresh gas. Put what you drained in your pick-em-up truck tank. Fill the tractor tank with fresh no-lead. Avoid the alcohol blends if you can. Pull the spark plugs and give each hole ten to fifteen pumps with an oil can filled with #10 motor oil. Look over the plugs for any problems, but don't expect any if it was running good when you last shut it down. With the plugs out, spin the engine for a minute or two. That'll splash oil all the upper cylinder areas and also re-fill and lube up the pressure feed oil system without any running load and stress on parts needing oil. Put the plugs back in. Remove the drain plug on the bottom of the carb. Open the tank fuel valve and let the system flush a bit with fresh gas. Put the drain plug back in and fire that thing up! Let it just sit and run at fast idle (800 RPM or so) for a while. After it has warmed up, check the oil. If you don't see the dipstick metal shine thru the oil film change it. Or, just change it anyway. From there, ponder the full PM schedule recommendations. Good luck, IHank
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
