Re: M timing gears
Posted by Janicholson on January 04, 2009 at 20:42:37 from (68.112.156.69):
In Reply to: Re: M timing gears posted by Bernie Steffen on January 04, 2009 at 18:52:17:
The cam gear hub is broken. It will still turn the other parts, but not the cam. The issue is pretty common. Radiator, Front pulley, front cover, and gears. (could be the keyway on the cam also. Use 400 or 450 gears. JimN
