Posted by Janicholson on January 05, 2009 at 06:26:23 from (199.17.6.128):
In Reply to: Re: 1086 broken dowel posted by Bemhoff on January 04, 2009 at 18:22:03:
You could drill into the bottom of the cavity through the side of the casting, and tap the hole for a greese fitting. Cast is easy to drill and tap Small hole, easy solution, quick Just take the fitting out of the hole when done and plug it with a dowel. Wouldn't want it to be greased later! A grease gun can make 12000 psi, it will come out! (you might need to measure the depth of a different dowel hole to assure the correct depth of the cross drilling from the deck down. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
