Re: Farmall H Not Starting
Posted by Janicholson on January 05, 2009 at 06:43:25 from (199.17.6.128):
In Reply to: Farmall H Not Starting posted by Phil in the hill on January 05, 2009 at 06:28:09:
Pull out the sparkplugs. I wuill suggest that water got into the engine and pulling the plugs will let it out. One other possibility is the starter could be jammed in the flywheel. Loosen the starter bolts and wiggle it. If the re is a clicking noise, that was it. The "repair" will last until it does it again. The cure is a new starter drive from CaseIH, or other sources. It is different than the original, and better.
A third possibility is weak battery and small cables. Cables should be O gauge wire, with soldered on terminals. This makes a big difference in cranking.
Try the plug removal first, then the starter.
Good luck, and tell us what fixed it, JimN
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
