glennster said: (quoted from post at 09:24:36 01/04/09) if it is a 12v coil, you can still use it on your m, even if the tractor is 6v. zip on over to your local napa, pick up an ignition ballast resistor for an early 1970's b body chrysler . they are about 4 dollars, its a ceramic looking doo- dad with 2 terminals on it. hook your battery power to one side, the other termainal goes to the coil .
If you use a true 12V coil AND a resistor on a 6V system, the spark will be extremely weak, if it sparks at all.
The 12V coil already has one resistor in it that cuts the voltage roughly in half. If you put 6V to the coil, it'll see 3V through the resistor.
Adding an external resistor will cut the voltage by half again. Now instead of 3V, the coil will only see 1.5V, about as much as a flashlight battery.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
