Re: More H questions
Posted by D Slater on January 05, 2009 at 07:45:42 from (72.65.148.97):
In Reply to: Re: More H questions posted by chad504 on January 05, 2009 at 05:39:19:
Nut needs tight enough to keep center of ball bearing from moving on worm steering shaft. Also bearing retainer cap needs to go in tight enough to hold the outside race of bearing from moving.
The best worm shaft bearings are made to stand up better to end thrusts. Lots found in tractors now are not as good but a lot cheaper and work for what most tractors are used for now. As Jim posted any front to rear motion from bearing or other is adding to more play. Others posted other causes, but you ask about the nut on horizotal shaft.
