mkirsch said: (quoted from post at 08:39:30 01/05/09)
....... The 12V coil already has one resistor in it that cuts the voltage roughly in half. If you put 6V to the coil, it'll see 3V through the resistor.
Adding an external resistor will cut the voltage by half again. Now instead of 3V, the coil will only see 1.5V, about as much as a flashlight battery.
A 6 volt system should not have any resistor in the circuit.
Other than that you have the right idea but the math will be a bit off. Adding the resistor to a 12 volt coil that has an internal resistor will only add about 50% more resistance rather than 100%. Assuming that the resistance of the external resistor, the internal resistor, and the coil windings are all equal, the voltage after the internal resistor will be four volts rather than three.
It really doesn't make much difference because either way the voltage will be too low.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
