May want to make sure the problem is with the T/A gears. When the T/A clutch is engaged, lever forward the gears looked at in rear compartment under cover don't turn. The whole unit that carries the gears turns. Was the t/a clutch release bearing replaced along with pressure plate? If the part t/a pressure plate is bolted to is turning when trying to move tractor, then some teeth on the gears or shafts, or a shaft is broken for the t/a unit itself to be the cause of tractor not moving with t/a lever forward. If the part the t/a pressure plate bolts to doesn't turn with t/a lever forward I would check clutch and adjustments again. The t/a side of t/a unit is probably not holding but whole unit failure chances of keeping tractor from moving in dirrect drive range is low. It happens sometimes though.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
