Re: No Power !
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bill {Antique Acres} on April 02, 2000 at 17:20:08 from (63.162.254.239):
In Reply to: No Power ! posted by bronco on April 02, 2000 at 16:55:37:
I had the same problem with my 48' Cub last year. I would start with all the common things. Make sure you are getting a good flow of gas, try adjusting the carb, check your plugs and make sure you are getting good fire. Replace your points. Check your oil for water, in my case my I had a head bolt break and caused it leak antifreeze in the cylinders. Report back what you find. Good luck Bill {Antique Acres}
Post A Followup
: Re: Re: No Power !
