Re: Generator Question??
Posted by Janicholson on January 05, 2009 at 19:27:16 from (68.112.156.69):
In Reply to: Generator Question?? posted by farmalldr on January 05, 2009 at 19:16:25:
The number of turns of wire in both the armature, and field windings. 6v has somewhat thicker wires and fewer of them. A six Volt gen can be helped to make pretty reliable 14 volts (charging volts for 12V batterys) if the field windings are changed to 12v. But not ideal. A true 12v gen was standard on many IH/farmall tractors, and should be not too hard to find. Red label on generator was used (as well as serial#) to indicate 12v. JimN
