When you have a crank shaft that is threaded it is always best to use that to pull the pulley back on. I have seen crank shafts broken when using a jack or just driving the pulley on with a hammer. Using a jack or hammer puts stress on the crank shaft all the way back to the thrust bearing. They will break between the first and second rod journal.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
