Re: Transmission cover
Posted by mkirsch on January 06, 2009 at 14:54:25 from (64.80.108.55):
In Reply to: Transmission cover posted by ed1 on January 06, 2009 at 14:26:51:
Don't quote me on this but I'm thinking you'll feel the difference if you miss.
To ensure no gear-mangling ensues if you do happen to miss, simply be careful when you go to move the tractor. If driving, let the clutch out slow in a higher gear with the tractor idling and if the tractor dies on you, it's stuck in two.
