Re: Super A Super C engine numbers Swapin' Parts
Posted by Hugh MacKay on January 06, 2009 at 15:02:45 from (209.226.106.189):
In Reply to: Re: Super A Super C engine numbers Swapin' Parts posted by georgeky on January 06, 2009 at 12:12:46:
George; Not completely right, all Super A after serial number 310300 used block 354898, same block as super C. The difference is sleeve thickness. That 310300 Super A happened about same time as first Super C was built. The Super A with thicker sleeves remained 3" bore, while the Super C was 3-1/8" bore. That same block can be fitted with 3-1/4" bore sleeves and pistons. Block 354898 was also used in 100 and 200, and is the only block in that group with 3 different bore sleeves available.
The blocks used in 130, 230, 140 and 140 only have a 3-1/8" bore sleeve available. The blocks before 1951 can also be fitted with 3-1/8" bore as well as 3" bore. All sleeve kits are specific to a particular block number. A and B used block 6342 DH, C and early SA used block 251069, Super C and late SA, all 100 and 200 used block 354898, 130 and 230 used block 366204 and 140 and 240 used block 367825.
