Re: Oil rings on pistons
Posted by teddy52food on January 06, 2009 at 17:13:41 from (209.237.111.169):
In Reply to: Oil rings on pistons posted by Blackland Dan on January 06, 2009 at 12:50:16:
I think you would be ok to use the 3 piece oil ring under the compression rings and leave the bottom one out. Is the rod drilled so the wrist pin is pressure lubed? It may make a difference, but I don't know for sure. Maybe tractor vet would know.
