Re: B axle removal
Posted by WOK on January 06, 2009 at 18:41:57 from (205.237.183.162):
In Reply to: B axle removal posted by Kevin Wieber on January 06, 2009 at 18:08:05:
The axle will come out with or when the drop housing is pulled away from the tube. You don't need get into the PTO or trans. The axle can be removed from the housing by removing the brake from the pulled axle and by removing the the plate on outside of the housing. The axle will then come out through plate opening.
