Re: Super A Super C engine numbers Swapin' Parts
Posted by Hugh MacKay on January 06, 2009 at 20:24:47 from (209.226.247.80):
In Reply to: Re: Super A Super C engine numbers Swapin' Parts posted by Wild Bill Caldwell on January 06, 2009 at 19:56:06:
Bill: There is also another little kink with 140 or 240, due to the fan hub water pump the head is different from all the others. I do know you have to use 140 or 240 water pump if using a 140 or 240 head, then your next problem is shroud and radiator not being right height for fan.
There are ways to overcome some of this. There is a guy used to post here quite regularly, Stan 22xx something. He has encountered this situation and can tell you exactly what you can and can not do.
