Re: Visual Check if 6 or 12 Volts
Posted by Nebraska Cowman on January 07, 2009 at 05:10:03 from (66.252.120.37):
In Reply to: Visual Check if 6 or 12 Volts posted by Retcol on January 06, 2009 at 18:56:59:
You can't. The best you can do is an educated guess based on what others have said. I assume it is as came from the factory until proven otherwise. Most older Farmalls were 6 volt positive ground. Post the model and somebody will tell you.
