Re: FARMALL 400 GAS /660 IH
Posted by mkirsch on January 07, 2009 at 06:09:32 from (64.80.108.55):
In Reply to: FARMALL 400 GAS /660 IH posted by GA Dave on January 06, 2009 at 16:44:55:
Okay, main question here is what do you mean by 400 engine? Do you mean the Farmall 400's C281, or a 400-series diesel engine commonly used in 66, 86, and 88 series tractors from 1973 up?
The C281 engine may bolt up with minor modifications because I suspect that the bell housing bolt pattern is the same; a 660 is just a 560 with a revved-up engine and planetary gear reductions at the rear wheels. You'll need to drill holes in the frame rails for the front engine mounts, and figure out all the fuel, electrical, and gauge hookups.
The problem with a C281 engine is that it only turns 1800RPM, while the 660's stock engine turns 2800 RPM. Ground speed will be unbearably slow; you will probably be able to plow in road gear. I suppose you could put a pulling-modified governor on the Farmall 400 engine to get the RPMs back but don't expect to use it for work unless you like rebuilding engines.
If you're talking about a D414/D436/D466, then it's going to be a huge project. Look for a D360 out of a mid '80s school bus or municipal truck if you want to put a modern diesel in the tractor.
