Re: Farmall Super C 6 volt vs 12 volt
Posted by Idaho Ron on January 07, 2009 at 16:10:16 from (208.98.173.2):
In Reply to: Farmall Super C 6 volt vs 12 volt posted by Red Mist on January 07, 2009 at 15:57:47:
Retcol said: (quoted from post at 00:57:47 01/08/09) I had posted before about trying to determine if the Farmall Super C was 6 or 12 volt. I noticed there is a resistor block on the tractor. Therefore, can I assume then the generator is 12 volt but everything else still is 6 volt?
From the factory the SC was a 6 volt. Does it have a battery in it? Does it run? all the 12 volt conversions I have seen have a neg ground, 6 v is a positive ground. Give some more info or pictures would even be better. Ron
