Re: Farmall Super C 6 volt vs 12 volt
Posted by Janicholson on January 07, 2009 at 16:15:42 from (64.83.227.252):
In Reply to: Farmall Super C 6 volt vs 12 volt posted by Retcol on January 07, 2009 at 15:57:47:
More than 50% of the time the owner will put a 12 volt battery in the tractor change to a ballast resistor, and leave everything else go to the dogs. Just charging the battery once every other day. So what I would do is to put a 12 volt battery in it, (light switch off, and generator field wire unhooked) and start it. I would then put a volt meter on the gen Armature terminal and short the F terminal to ground. If it reads less than 10 volts, I would assume it is 6 volt, if it begins charging the battery, and reading 13.8 to 14.5 volts, It is a 12v gen. JimN
