Re: SMD Mag to distributor question
Posted by Nebraska Kirk on January 07, 2009 at 19:04:59 from (207.91.30.8):
In Reply to: SMD Mag to distributor question posted by Marv on January 07, 2009 at 18:45:46:
The distributor is 180 degrees out of time, you can either remove the distributor, rotate the distributor drive 180 degrees and reinstall, or just move the plug wires on the cap. #1 plug wire to where the rotor points to when #1 piston is at TDC, going counterclockwise from there, next position is the #3 spark plug wire, then #4 and finally #2.
