Posted by old on January 07, 2009 at 19:39:45 from (4.245.4.179):
In Reply to: C Not Starting posted by Rusty White C on January 07, 2009 at 19:00:29:
Lets start at the top and work back so to speak. First off make sure you have a good white/blue spark that will jump a 1/4 inch gap. No spark all the gas in the world and it still not run. Pull the cap, rotor, dust cover. Turn the key on and with the points closed open and close them by hand. Do you get a spark/snap at the points?? If yes then check to make sure it will jump that 1/4 inch gap. If it does both then pull the air intake tube off and hold your hand over the carb and spin it over. MAKE sure its out of gear. It should suck on your hand pretty good and you hand should get wet with gas. If it does then you have low compression for some reason. Sticking rings or valve or both.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
