Posted by El Toro on January 08, 2009 at 03:50:10 from (64.12.116.73):
In Reply to: Re: C Not Starting posted by Rusty White C on January 07, 2009 at 19:20:18:
If there's very little suction on your hand when over the throat of the carburetor means you have very little intake manifold vacuum. Do a compression check and see how your compression readings compare. Make sure you're getting battery voltage to the coil. With the points open your should have battery voltage on both small terminals. Clean those points with some 320 wet or dry until they're shiny. Remove the sparkplugs and squirt engine oil into the cylinders then bump the engine over a few times. Make sure your plug wires are on the cap in the correct firing order should be like this. Hal PS: Since the rotor turns CW. 2-1 4-3
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
