Re: No fuel pump (fuel pump bypassed)
Posted by glennster on January 08, 2009 at 14:20:05 from (76.223.245.56):
In Reply to: Re: No fuel pump (fuel pump bypassed) posted by spiffy1 on January 08, 2009 at 12:08:12:
napa has some smaller electric pumps for lawn equipment applications, 1-4 psi and 3-6 psi ratings, if you knew the output pressure of the factory pump, you could match em up, other wise, go with the bigger pump and add a fuel pressure regulator to adjust the pressure. i would guess you want no more than 4-6 psi fuel pressure, too high and it would push fuel right past the float valve.
