Re: Dupont Primer
Posted by CNKS on January 08, 2009 at 17:20:44 from (216.144.104.128):
In Reply to: Dupont Primer posted by spiffy1 on January 08, 2009 at 15:30:48:
If you are using DuPont paint, go to their website and follow their instructions. There is no reason to experiment. You really shouldn't primer disassembled and then topcoat when assembled. There will be areas that don't get topcoated because you will be topcoating at weird angles and simply will not be able to cover the primer completely without getting runs in your topcoat. There are no shortcuts if you want a good job. As Gordo said, epoxy primer is usually the way to go. But, you don't want to use it if it goes against DuPonts instructions for the particular paint you are using. You shouldn't try mixing brands of paint.
