Re: Extracting broken bolts
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by p on April 02, 2000 at 23:09:26 from (166.90.85.80):
In Reply to: Extracting broken bolts posted by RedTed/MO on April 02, 2000 at 06:25:24:
have also heard of people heating the area and put a candle down on the bolt, the wax will soak down to the threads and aid in removing the bolt. I know it sounds fishy but I know professional engine rebuilders who swear by this....p
Post A Followup
: Re: Re: Extracting broken bolts
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
