If there is any significant amount of oil the coolant it is usually the oil cooler that is leaking. When the engine is running the oil will go into the coolant. When you shut it off, the pressure remaining in the cooling system will now force coolant into the oil system. I have seen them leak so much that the oil and coolant both looked the same.
Leaking sleeves do not usually put any significant amount of oil in the coolant. Nozzle sleeves will leak coolant into the cylinder but no significant oil back into the cooling system. Unless the fuel system has been turned up head gasket failures are not too common.
I would remove the oil cooler and test it. I have a couple of plates that bolt on the cooler, one with an air nipple. I flush out the oil side, install the plates and apply air pressure. Stand the cooler on end and fill the water jacket with water. Watch for bubbles.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
