Posted by D Slater on January 09, 2009 at 09:55:11 from (71.164.44.66):
In Reply to: Re: '41 H seat deck posted by FarrviewWest on January 09, 2009 at 06:46:45:
Used H serial # 62509 X1 on dairy farm for years. Only the two 5/8 bolt holes closest to steering post were used to mount the curved pipe seat with spring and mounting bracket located at front of pipe. Also used a starter switch in rear fuel tank support and a rod through hole near bottom of steering post to engage switch. I see your tractor has the holes. Tractor worked a lot of plowed ground without seat falling off.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
