Posted by Bob on January 09, 2009 at 14:35:34 from (69.178.228.68):
In Reply to: B275 electrical posted by howling wind wayne on January 09, 2009 at 14:08:06:
Since this is diesel tractor, there's no ignition system to worry about, so it's REAL simple.
With the engine shut down, swap the battery connectionss, then POLARIZE the GENERATOR before startup.
What electricals does this tractor have... USA made Delco?
If so, momentarily jumper between the "BATT" and "ARM" terminals at the voltage regulator BEFORE startup.
("GEN" is an alternate name for the "ARM" terminal.)
IF the generator is another make an alternate procedure might be required. (IF it is a "B" system generator.)
NOTE... some voltage regulators use different metals for the upper and lower contacts, set up to work best with one polarity or the other, and operating the regulator with the reverse polarity MAY shorted contact life somewhat.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
