Re: 400 grief
Posted by r4etired on January 09, 2009 at 15:27:10 from (166.227.83.237):
In Reply to: 400 grief posted by Dodger on January 09, 2009 at 14:58:28:
Have you done a compression test on it. You might take the valve cover off and check if the valves are working properly. I would check the distributor shaft for excessive play. It is also possible you have broken gear on the pump,distributor drive. These old engines are pretty forgiving so you must have something pretty major wrong if it won't run at all.
